Galant VR-4 Forums » Marketplace » Parts For Sale » FS: Spring Cleaning (Various Parts) [Updated 6/7/21]
mooserage Galant VR4.org Administrator
New Title
254/2000
Galant VR-4 org Post #: 1250581 posted 03/27/21 01:33 PM     Remind Me!  Send Private Message   Edit Post
Cleaning out my garage, will add parts as I can...
Have a lot of parts, prices include paypal fees, but not shipping. Open to reasonable offers and package deals.
Good Guy Thread for Reference: Click
Part 3:
NGK BPR6EIX Iridium Spark Plugs - $10 Click1
CM (Certified Muffler) 3" Cat Delete Pipe (Test Pipe) - $80 (Info: Click) Click1
NOS Grey OEM Wingless 3rd Brake Light - $40 Click1 Click2
Sending to Ebay 6/13 Flex-a-lite (FAL) 12" Fan - $20 (Cut-out for BOV clearance) Click1
Sending to Ebay 6/13 OMP Universal Co-Driver Aluminum Footrest - $20 New, but assembled for fitting Click1
ETS Intake w/ -10AN BOV Return, K&N Filter, Elbow for 16G Turbo - $110 Click1
New OEM Heater Hose Kit MB527995 - $45 Click1
Part2:
New AMG Replica Grill - $40 Ebay Ad Info (Still in the packaging, went a different route) Click
Part 1:
New Allstar 3" Brake Duct Hose (300*) - $25 Click (I used a little, it didn't work out, there is at least 8' still there, likely more)
New Summit Racing 6AN SS PTFE Hose (15') and hose ends(2x straight, 2x 45*, 2x 90*) - $100 click 1 Click 2
Sending to Ebay 6/13 AEM EMS V1, Serial Gauge, IAT, MAP Sensor, Brantz rally trip meter, Harnesses (Not pictured, but included: Serial Cable) - $500 Click (Ran the car with this for nearly 10 years, decided to go to ECMlink)
Sending to Ebay 6/13 RC 550s - $70 Click (Worked great for years, probably need a cleaning)
Galant Non-ABS Brake Lines and Proportioning Valve - $40 Click 1 Click 2 Click 3 Click 4 (Bought used, never used myself. Shipping will be expensive, some lines may need slight massaging to get into perfect shape)
Sending to Ebay 6/13 AVC-R - $165 Click
Free Pile! (Free, but you pay shipping)
To recycle on 6/13 OEM Brake Reservoir w/ sensor Click1
To recycle on 6/13 OEM BOV Return Hose Click1
To recycle on 6/13 OEM Fan Blade & Motor (Working when pulled) Click1
To recycle on 6/13 OEM Water Pipe & Water Cooled Oil Filter Housing Click1 Click2
Battery Cutoff w/ Removeable Key Click1
100AMP and 150AMP Circuit Breakers Click1
BNIB Russell 626010 120* -8AN Twist-Lok Hose End Click1
To recycle on 6/13 Galant VR-4 ABS proportioning Valve (pulled working about a year ago) Click
To recycle on 6/13 USDM Summit White fuel door Click 1 Click 2
To recycle on 6/13 Galant ABS computer core Click 1 (trunk mounted unit, disabled for the 15 years I owned the car, consider it a core)
To recycle on 6/13 Galant ABS Hydraulic Unit core (disabled for the 15 years I owned the car, consider it a core)
To recycle on 6/13 Cut up stock intercooler tubing, believe this was used to adapt a JDM Galant intercooler click
*GONE* OEM Dipstick & Tube Click1
*GONE* Almost New Autometer 52mm (2") Gauge Pod Click1
*GONE*Energy Suspension tie-rod boot Click
*GONE* OEM Summit White Fuel Door and Lock Click1
*GONE*JDM hood vent rain guards Click 1 Click 2
*GONE* Blue Aeroquip FCV0606 6AN 6' Socketless Hose Click
*GONE* Galant throttle body and oil pan gaskets Click
*GONE*Partial Energy Suspension control arm bushings (large bushings only) Click
*GONE* OEM Rear Bumper Marker Lenses Click1
SOLD
*SOLD*NOS OEM Keyless Fuel Lid - $30 (Factory primed, some scratches in primer)Click1 Click2 Click3
*SOLD* New Prothane Poly Motor Mount kit - $65 Click
*SOLD* New Aeroquip 6AN PTFE SS fuel hose (20', Aeroquip FCC0620) w/ used and new steel fittings - $80 Click
*SOLD* STM ARP Stainless Exhaust Manifold Stud Set - $80 Click
*SOLD* New English Racing 2G/Evo 1-3 Phenolic Intake Manifold Gasket and Hardware NLA - $50 Click
*SOLD* Trick flow 6AN Fuel Filter w/ new 40Micron filter - $25 Click
*SOLD* AEM Tru-time Cam gears - $100 Click 1 Click 2 Click 3 Click 4 Click 5 (see photos for light damage on teeth)
*SOLD* New Ingalls FastCam Front Camber Bolts (Pair) - $30 Click
*SOLD*JDM Grey Keyless fuel door - $40 Click 1 Click 2
*SOLD*Evo III Intake Manifold Powder coated Silver - $170 (bought used, never used myself, you'll need to add your own hardware to to mount the throttle body) Click0 Click1 Click2 To garbage on 6/13
Edited by mooserage (06/07/21 08:24 PM)
Posts: 1256 | From: Seattle, WA | Member Since: 05/17/04 | IP: (73.19.21.252) | Report this post to a Moderator
yubh8tn
1384/2000
Galant VR-4 org Post #: 1250582 posted 03/27/21 07:49 PM     Remind Me!  Send Private Message   Edit Post
whats the durometer of the motor mounts?
Belize Green 1384/2000
1998 Integra
Posts: 116 | From: coeur d alene, idaho | Member Since: 08/21/19 | IP: (2600:100f:b00a:e) | Report this post to a Moderator
467
mass moment of inertia
467/1000
Galant VR-4 org Post #: 1250583 posted 03/28/21 05:28 AM     Remind Me!  Send Private Message   Edit Post
Interested in the fuel door. Is it kensington grey or some other grey?
Posts: 915 | From: Fremont Ca | Member Since: 03/16/01 | IP: (73.222.214.55) | Report this post to a Moderator
kdott96
733/2000
Galant VR-4 org Post #: 1250584 posted 03/28/21 07:30 AM     Remind Me!  Send Private Message   Edit Post
I'll take the oil pan and tb gaskets please. Shoot me a text -> 646-244-9982. Thanks
Kevin T.
1991 Galant GSR
1991 GVR-4 733/2000
Posts: 61 | From: Valley Stream, NY | Member Since: 03/02/16 | IP: (71.190.103.141) | Report this post to a Moderator
New Title
254/2000
Galant VR-4 org Post #: 1250586 posted 03/29/21 12:56 PM     Remind Me!  Send Private Message   Edit Post
*Marked items that are pending* In general, it's easier for me to track things over PM, but will eventually text those that requested it, but may be slower. Thanks.
yubh8tn: Not sure what durometer the Prothanes are, they are definitely stiffer. There are some reviews over on tuners, as well as some different how-tos on installing them.
467: Fuel door is pending at the moment, not sure what the grey is, you'd have to check the grey color codes for JDM cars to confirm if they had a slightly different color (like sofia vs summit white) or not.
kdott96: Clarifying if someone else wanted the TB gaskets or not and will follow up if they don't. Confirmed these are sold.
Edited by mooserage (04/05/21 08:37 PM)
Posts: 1256 | From: Seattle, WA | Member Since: 05/17/04 | IP: (205.166.76.242) | Report this post to a Moderator
New Title
254/2000
Galant VR-4 org Post #: 1250609 posted 04/09/21 01:19 PM     Remind Me!  Send Private Message   Edit Post
Bump, some prices adjusted, will try to add more parts this weekend.
New Title
254/2000
Galant VR-4 org Post #: 1250690 posted 05/01/21 06:29 PM     Remind Me!  Send Private Message   Edit Post
More parts added, most prices dropped, going to turn into "summer" cleaning at the rate I'm going...
254/2000 Summit White
93graybird
What do you mean title?
950/2000
Galant VR-4 org Post #: 1250705 posted 05/04/21 12:59 AM     Remind Me!  Send Private Message   Edit Post
Messaged
950/2000 Nile black
Posts: 2 | From: Fielding Utah | Member Since: 04/22/21 | IP: (65.154.114.86) | Report this post to a Moderator
New Title
254/2000
Galant VR-4 org Post #: 1250866 posted 06/02/21 12:47 PM     Remind Me!  Send Private Message   Edit Post
Spring is pretty well over and I need to free up some space. I've marked the things that I am going to recycle or throw on eBay in 2 weeks. Open to reasonable offers and deals if you're interested in anything. I will be storing the remaining items, so may be a little slower to send anything out after they are stored.
My90gsx
Newbie
Galant VR-4 org Post #: 1250880 posted 06/04/21 03:54 PM     Remind Me!  Send Private Message   Edit Post
Hey, will take spark plugs, 12" fan, and rear bumper marker lights. Just get me total with shipping to 47274.
Thank you!
Posts: 3 | From: IN | Member Since: 06/04/21 | IP: (162.211.38.50) | Report this post to a Moderator
New Title
254/2000
Galant VR-4 org Post #: 1250891 posted 06/07/21 01:49 AM     Remind Me!  Send Private Message   Edit Post
Pm'd
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Generated in 0.034 seconds in which 0.004 seconds were spent on a total of 13 queries. Turbo powered.
