WTB: turn signal flasher relay
turbophein
mass
my turn signals won't work anymore, hazards still work though. pretty sure its the relay, hope its not the switch!
Wizardawd
Franklin, NC
just switch the 2. They should be the same #55 relay. If the problem switches, then its the flasher. $3 at any local parts store.
Wiz
turbophein
mass
the hazard and blinkers work on the same flasher. i tried an autozone flasher, it didn't work. but i figured my problem out. i installed a turbo timer all to find out it wasn't working, when i removed it a few days later, the signals started working again. so it was the TT causing my problem
