I have what appears to be a good condition G4CS short block. Pulled it at a local yard a few months ago with ~110k miles on it. Short block is complete with crank, rods, pistons, and oil pan. I haven't pulled the pan but everything rotates fine. Car appeared to have transmission issues and it's demise likely had nothing to do with the engine.
Additionally, I have a complete/built G4CS block with Eagle rods and Wiseco pistons that spun a thrust bearing after 50 miles. Block and crank are likely bad but the rods and pistons should still be perfect. All parts are located in Southern California.
Pulled the newer engine due to rarity as I never see them anymore. Wanted to give myself the option of rebuilding the second engine if I ever got around to it but I may be willing to sell it all if anyone has a use for it.
Thanks,
Tim
