WTB:4 lug awd rear hub
theevozero
Odessa, Texas
^THIS^ Just to clarify, I need one for a vr4. Go figure. Went to replace a wheel speed sensor that had an open circuit and low and behold, that same hub has a ton of play in it. I take the hub apart to replace the bearings and find that the hub had spun inside the bearing race. So, needless to say, my abs is inop right now and I can't find a abs diagnostic trouble code chart....yet. But, I am assuming the loose hub is the problem. The light comes on when I cross the 4 mph mark.
theevozero
Odessa, Texas
click,r:0,s:27,i:165&tx=39&ty=225&vpx=111&vpy=143&hovh=194&hovw=259
The ones on the left are rear and the right are front.
I probably have one of these as well. Did you check your tooth counts for the ABS tone rings? If those are not correct that can cause the light on when you get moving fast enough.
theevozero
Odessa, Texas
I have not checked all of the reluctor wheels, no. The only ones that could even possibly be damaged would be the fronts. The rears a hiddin inside the hub. I probably should anyway. I know the one on the LR wheel is fine though.
