Won't shift into 1st
Dahcrow92
Member
Fairbanks, AK
Newbie here. My galant won't shift into 1st gear. I have a new TRE transmission and a new TMZ t-case. All other gears shift fine just won't shift into 1st. Any ideas on adjusting the shifter back or just any idea on fixing this problem will help.
pot
Fayetteville, NC
A couple quick thoughts. You probably did these things already but I would do it again particularly the first two.
1.) Adjust your shift linkage at the the Shifter/Trans
2.) Bleed the Slave Cylinder
3.) Bleed the Master Cylinder
Dahcrow92
Member
Fairbanks, AK
How do you exactly adjust the shifter/trans? I know how to adjust it left to right. All gears were shifting hard before that. But I read somewhere online were you can adjust it forward and back to help with the 1st gear. That is what I do not know how to do
Evolv23
Member
Las Vegas
Jafromobile has some good vids on youtube if you haven't already to give you ideas. Weird how it's only 1st gear.
