Wipers Don't work!
desant78
Clarksboro, NJ
Hello gvr4.org
Before I took my car apart, my wipers didn't work. I put my car together, and they didn't work.
Then randomly they worked but after a few minutes slowed down and stopped moving, in the upright position. They do not move at all anymore. I have a parts car, with a complete wiper system that worked. I have DSM shop manual, so I fear it will not match the vr4. I am going to trouble shoot the system with the manual, but am looking for suggestions on what parts to change. From reading online, I found a simple list
1. relay
2. motor
3. motor control board.
I already switched the relay with no luck. Any input and suggestions would be greatly appreciated!
thanks!
misterfixit
Midlands, UK
Pull the motor off the parts car.
It will have the same plug as the galant. Hook it up and make sure it's grounded (cable under one of the bolt heads to the inlet manifold or battery or like)
Does the parts motor work smoothly?
If the answer is yes, pull your motor. Snap it off the linkage. Try the same again.
Does your motor run smoothly?
If the answer is yes with the motor removed still check if the linkage moves smoothly. if it does then all is good, if not you need to rebuild the pivot shafts. (remove circlip, strip, degunk, clean the shafts, regrease and reassemble)
If the wiper moroe is slow/snaggy then pull the can off (mark it for timing before you do) and check the bearings and brushes. You should be able to rob the dsm one for a new brush plate or body if need be. Timing of the can is important or it will park halfway up the screen.
On my flooded Lancer I tapped and recoated the threaded holes on the firewall and ran a jumper cable to the main body of the motor to ensure ground was maintained. If the motor base is crustyo then you may need to do the same.
hope this helps,
Rich
desant78
Clarksboro, NJ
^thanks for the tip! with the extra motor, I attached the motor plug and ground to the car, and attempted to energize the motor outside the fire wall, not attached to the linkage. Nothing happened.
Following the above post, I have hit a dead end, feel free to comment while I look in the DSM electrical manual to try and solve this problem.
mitsuturbo
Near Seattle, Washington
Parts car?
Pull the combination switch. Plug it into your GVR4 harness and see if the wipers will come on with it. Since a 2nd motor won't work, i'd assume it's the switch or wiring. The switch is a lot more likely than wiring. If the switch doesnt fix the problem, ohm out all the wiring.
LIV4PSI
O-H-I-O
What could be confusing about the term 'parts car?'
Edit: I guess maybe you are asking if it is a DSM or a GVR4
desant78
Clarksboro, NJ
Update: I changed the motor AND the combination switch, and nothing, no luck /ubbthreads/images/graemlins/bawling.gif Any more suggetions before I try to OHM out this nightmare?
