Windshield Wiper Problem
When I turn off the wipers in my galant, they stop in place wherever I turned them off at. They do not return to the down position when I turn them off unless I actually turn them off while the wiper is down. Does anybody know what could be causing this? Thank you
SouthCaliVR4
North county San Diego
check that you have one wire providing constant power to your wiper motor at the connector, key on wipers off. if you do have your constant bat+ the motor itself is bad. The part that need constant power is the park position switch in the motor, same part failing will cause this.
14u2nV
Agency/St. Joe, MO
I had that problem, swapped out the relay and solved it. The one I swapped is one of the two located by the driver headlight. Don't know which one it was though.
