Window trim
CutlassJim
Manchester, NH
I pulled off the trim and now I can't figure out how to put it back on. Pics would be good since I read at a third grade level and wipe my ass with my shoe. (Not really but I feel that dumb not being able to figure out how to put the trim back on correctly)
CutlassJim
Manchester, NH
No I'm talking about the thin metal trim on the sides and top with the gray mounting clips. The clips don't seem to want to hook back onto the glass. I was wondering if the little tabs sticking up are involved or not. /ubbthreads/images/graemlins/dunno.gif
GVR4_1057
Brucetown VA
You mean on the windshield right? Those suck. I had a windshield replacement guy install mine,it worked out great. The top one will fly off at speed if it is too loose.
The gray "wing" clips are only tensioners. the other clips are what hold the trim on. Many times these break because of age when you remove the trim.
I don't know the difference, but 91 clips are green, and 92s are orange for some reason. (Maybe that is only the rear...hmmm, can't remember). Usually those clips are in there quite will with the windshield urethane and may need to be cut out to replace them. They slide over the small "T" studs in the window channel.
