Wideband thru firewal
boostme
Crete, IL
Do you guys enlarge the hole or replace the grommet with another one that is above the steering column? I already run a vacuum line thru there, but that is slimmer.
I'm wanting to install a wideband but where do I route the plugs thru? Its cold out lol
mooserage
Seattle, WA
I ended up running mine through the speedo cable hole. I pushed the grommet out and used a universal one with some sealer. Its good to know its sealed, but first time I have to replace something will be a bit of a pain to re-do it.
