Where to order a datalogger??
Hi!!
I'm now after a datalogger for my VR-4, where can i order a logger with cable and everything??
Anyone that has ordered from obdlogger.com or digitaltuning.com??
Which program is it that those places sell together with the loggers?? I only know of MMCD /ubbthreads/images/graemlins/dunno.gif
Thanks // Wolfy
No i have a single board EPROM ECU!! /ubbthreads/images/graemlins/smile.gif
What is involved in the install? My computer is to slow /ubbthreads/images/graemlins/banghead.gif
Directions for Installing Logging Software
1. Put the labeled Palm Desktop CD into your desktop/laptop computer
2. Install the contents of that CD onto your computer
3. Using the black Hot Sync cable connect the Palm Pilot to your computer
4. Go to the Start Menu, Programs, Palm Desktop, then click on the Palm Desktop Icon
5. Insert the unlabeled Cd into your CD Rom drive
6. Click on the “Install” button on the left hand column of the Palm Desktop Software
7. Click the “Add” button
8. Using the drop down menu select your CD Rom drive
9. Double Click the file name MMCD.prc
10. Close the install window
11. click “ok” to the dialog box that pops up
12. Press the Hot Sync button on the black Hot Sync Cable connecting the Palm to your computer.
13. Allow the hot sync to complete and disconnect the Hot Sync cable
Directions for Hooking the Logging cable up to your Car
1. Locate the Diagnostic Port next to the fuse panel under the drivers side dash
2. Connect the three free wires on the logging cable as shown in the diagram:
3. Connect the black Hot Sync cable to the gray datalogging cable
4. Connect the opposite side of the black Hot Sync cable to your Palm Pilot
Directions for Running the MMCD Logging Software
1. Turn on you Palm and make sure the upper right hand drop down menu says “all”
2. Click on the MMCD logo
3. Click “new”
4. Uncheck “pause”
speedyvr4
miami, fl
Greg's cord is the burliest I've seen too...better than any of the eBay garbage.
I have the ebay garbage /ubbthreads/images/graemlins/grin.gif. I bought the same reman. palm for 40 bucks at fry's electronics and the cable off ebay w/ the mmcd software. Also bought the serial cable (palm to cable) from ebay.
palm = 40 bucks
ecu cable = 15 bucks
serial to ecu cable = 10 bucks
being a cheap bastaerd with a dsm and a gvr4 = priceless /ubbthreads/images/graemlins/idea.gif
so for 65 bucks I got everytiiiiing
110 not a bad price though. my 2 psi
I don't consider the eBay cable I got from countdepoligonize to be junk. It seems to be well-made, is auto-ON, so it doesn't interfere with the ABS, and he will ship it with either a MALE or FEMALE connector, so it will work with Palm or notebook. For $5 more he shipped it with a null-modem adapter so I can use it with both. /ubbthreads/images/graemlins/wink.gif Not bad for $25.
How many logger programs is there available for the Palm??
It seems like there is many programs, which one is better than the other programs??
// Wolfy
Already done that /ubbthreads/images/graemlins/wink.gif
Is that a good program to log with?? Or is there better programs than MMCD??
Ok!!
Which PDA's works with the MMCD program??
Does the other logger programs have the same PDA support system as the MMCD has??
Why don't the Palm Zire 22 wont work as a logger?? I mean, i know that this is a USB unit but shouldn't it work when i use the RS232 serial cable?? Or is it the programs like the mmcd, palm 'n' stein and dsm logger and so on that don't work on these units??
I mean, the Zire 22 are some nice units /ubbthreads/images/graemlins/cool.gif
Some one that knows a answer on this question??
Thanks // Wolfy
