Wheel + hub cone = wabble
tektic
ronkonkoma, ny
I have evo x wheels and need 5mm spacers upfront to turn lock to lock. The rims have a taper cut in to them in the hub area, and because of this and the spacer the rims do not contact the hub to center it. What if anything can I do to fix this?
Hubcentric spacers. I ordered some from ebay a long time ago. They basically have a machined center lip that matches the hub diameter to center the wheel on the spacer the same as it would on the hub.
tektic
ronkonkoma, ny
The picture for 5mm is a generic. There's no place for a ring to go on a spacer so thin. I'm going to try to get some 59mm to 67.1mm rings, and turn them down to fit the interior ring of the hub. Like an extension. I can't find an off the shelf solution... Like usual.
