wheel bearing
presterone
brunswick maine
Best place to order a front wheel bearing? Should I buy an outer race as well? is there an inner and outer? I assume they are not dealer available maybe they are. Is there a VFAQ writeup on this? the site is down or something. I have access to a bearing press.
Only one bearing each, sealed ball type, with no separate races. Have to have the front hub pressed into them, and the bearing is pressed into the knuckle and retained with a large snap ring.
You can buy them aftermarket, but I usually buy OE mitsu (yes, a bit pricier, but try JNZ. Get new seals for both inner and outer both sides (4), as they get wrecked during the removal process.
