Wheel bearing/hub assembly
OneEighteen
New member
Cherry Hill NJ
1991 vr4 ..... I have to change all of the hubs on my car because previous owner said they are all bad, so here's the question I have. Where to get these at? Are the fronts and rears the same because I can only seem to find the fronts.
thomcasey
Indianapolis, IN
Hubs rarely go bad as they just hold the lugs. Replacing the bearings is all you should need to do on the front or back unless there is physical damage to them
idreamidrive
Murray, KY
Vfaq.com is your friend.
You can loan the tool from AutoZone to do the front. For the rear all you really need is a slide hammer and hope your bearing races come off.
