What Transmission Fluid/Gear oil do you use?
dsmkid
Denver, Co
Im planning on doing a flush today on the gvr4 I just got and just wondering what you all would suggest. What do you use and have good luck with? I am experiencing some 2nd gear grinds at high rpm and its hard to get into 2nd at 7k at the track. I know the culprit is probly not a fluid problem but hopefully it can help it a bit. Keep in mind I live in Colorado and we do get Cold winters, sub freezing. This will be what I use all this winter. Thanks in advance!
Launch
Texas
Only motul in my high tq trans, wax kills. shockproof in transfer and rear
Dark_Horse
Morrison, CO
Since you live in Colorado, I wouldn't run heavy shockproof in the winter. Heavy doesn't like temps below 45 degrees.
cupajoe
Cocoa, FL
Mitsubishi Diaqueen in the transmission and Heavy shockproof in Tcase/rear diff. But I'm going to switch my transmission fluid to MT-90(2/3) and MTL.(1/3)
turbofonz
Granby, MA
I'd run straight MT90 for now.
When spring comes around and you start beating on it a little more toss in some shockproof for some...shock proofing.
