what exhaust are you running that allows you to go low?
I'm running a thermal 3in cat back. 2 to flex pipe to 2.5 down pipe. I'm lowered a little in the front and I think stock in the rear. Front springs are red and rear are black, no writing on them. But I scrape the exhaust easily. I have a drive shaft loop that if I get rid of looks like I can save an inch, but the rear is about a half inch from the diff and lower control arm, I don't see how I can save any space there.
gtluke
dirty jersey
usually the exhaust scrapes up by the flex section. Can you confirm? It might just not be mounted as high as possible, or the cat is hitting the ground? Pics?
SouthCaliVR4
North county San Diego
My certified 3" turboback has rubbed on the flex section but otherwise is up way to tight to make contact with the ground. Even when I lived on the island & had to drive onto the ferry at extreme low tides it didn't rub. Now I did have a couple issues with it contacting the driveline in heavy rain due to it warping when puddle splash cooled a section. A couple dimples & trimming the edge of the converter fixed that right up.
Quoting gtluke:
It usually scrapes by the flex section, sometimes at the rear by the diff. No cat. Car is up in the air at the moment and I took the exhaust off, so no picc.
Terry Posten
Davenport, Iowa USA
You are not that far away, look at my "rides" post and look at my exhaust. click
My friend has an exhaust shop in DeWitt, IA and I can hook you up. That is one piece, custom bent, from the down pipe to the muffler. It is crush bent but if you are not trying to get the last 15 hp from a 500hp+ engine, it won't matter.
(no questions asked, wink, wink, wink.)
