What crank pulley?
Mine is cracked around the edges, so I've been researching lightweight ones. I don't see any problems with them, sounds like a good idea to me?
But there are many that say it's a bad idea, but have no proof to back it up...
I don't want to under drive my accessories, but I do want my engine not to work as hard (lighter would mean this, correct)?
I have really only seen unorthodox brand, are these a different diameter than stock?
mitsuturbo
Near Seattle, Washington
Some people advise strongly against using a solid aluminum lightweight pulley like the Unorthodox ones.
I ran one for a long time and saw no ill effects. I'm not really for, or against them, per-se. It's up to you.
Here is a discussion on the subject: click
LIV4PSI
O-H-I-O
The stock crank pulley is a harmonic balancer. Lightweight pulleys are not. Will your car blow up from removing the harmonic balancer? Of course not. Is there better ways to make horsepower or for that matter remove rotational mass? In my opinion, of course. Its a crapshoot as posted above.
So maybe I should drop the 140 on a new OEM one, my goal is reliable fun car, and I've been dropping some crazy coin on this project!
Quoting LIV4PSI:
No, it really is not. The crank and pistons are balanced internally, not externally (which requires an actually harmonic balancer). It is a damper (think the springs in the clutch) albeit a very stiff one. That is what you lose going with a solid one.
LIV4PSI
O-H-I-O
I have always heard it referred to as a harmonic balancer, thank you for clarifying. I bought a used Fluidampr pulley for 1501 off of Craigslist for $150, still new in the box. They are a little pricey otherwise, but I like retaining the damper. Its a game of inches after all, and it helps with my peace of mind.
