Scott Y
Summary:
Fuel pump operates normally when started via DSMlink with the engine not running, but starts making strange noises after engine is started. I put about 1000 miles on this configuration, and one day out of the blue the noise started. At first I thought it was something loose in the exhaust.
Fuel System
- intank Jay Racing uberBosch 044
- rewired with 8gauge
- 6an line to stock rail, Aeromotive AFPR, stock return line
- full tank of E85
- tank is spotless inside
Electrical Info:
Voltages
Engine not running, pump engaged via DSMlink
V(battery) = 12.14VDC
V(pump) = 11.86VDC
V(pump running) = 11.39VDC
Engine running
V(battery, engine@idle) = 14.39VDC
V(battery, engine@4000rpm) = 14.45VDC
V(pump) = 14.10VDC
V(battery, engine@idle) = 25.8mVAC
V(battery, engine@4000rpm) = 29.7mVAC
ECU caps replaced in 2000.
Troubleshooting steps already performed:
- Return line removed from tank and fuel directed to jerry can: No change
- Fuel pressure adjusted via AFPR as high as 60 @ idle: No change
- Power line run external to car from battery to fuel pump: No change
- Power line plus new ground from sending unit independent of car harness: No change
- Different known good battery: No change
- Known good battery sitting on floor, connected to (+) & (-) of pump, car harness disconnected from pump: pump runs perfectly! Of course, the pump cannot be controlled via the ECU. The pump was running while connected to the 2nd battery , then the engine was started.
Video of the behavior
Ignore the low fuel warning light, I probably hurt the sensor as I've had the sending unit in and out of the car at least 10 times and it's a wrestling match every time . The tank is known full.
I've been fighting this one for weeks and it is putting the hurt on me.
Fuel System
- full tank of E85
Electrical Info:
Voltages
V(pump) = 11.86VDC
Engine running
V(pump) = 14.10VDC
