water and methanol
Eighty9TSI
Livonia, MI
No, not the fuel rail. Its injected into the throttle body/intake pipe before the throttle body (maybe even the manifold if it calls for it) and it mists the solution into the air, pushes it into atomization even furthur and then gets sucked into the cylinder where it goes boom. It then absorbs some of the combustion energy and effectively cools off the 'explosion' that is occuring. Water is pretty hard to burn, so having to flash the water droplets into steam costs energy (its not free) and thereby steals some of the combustion heat and lets the cylinder burn cooler while adding all that extra air, that under normal conditions, would have caused excessive cylinder temps which would/could contribute to detonation/pre ignition.
I figured I would explain the process so you would get it inside and out.
you can also use HEAT from your local auto store
if you want to take full advantage of W/I you need to dynotune it, not just install it. Youll lose HP by installing it, then you need to retune it on the dyno.
ken inn
krum texas
huh? where do you get this from? i had water injection for years. all i saw was knock eliminated(more timing, more boost, more power), less fuel needed(again, leads to more boost, more power), lower injector duty cycles(more boost, yada, yada), super clean intake tract, intercooler, entire combustion chamber, valves, spark plugs(more efficient intake, intercooler, therefore more boost, yada, yada).
Because I work at a dyno? we install tune SNOW kits daily.
Yes you are right. Your a/f is going to lower a certain point depending on what PSI you are using, nozzle size, and method of spray (boost, rpm, gear, map, etc.)
All I was saying was that installing it and driving off with no additional tuning will make him lose power. He needs to watch his timing and knock on a dyno while upping the boost and keeping his a/fs safe. Usually to the same a/f as before pending he was safely tuned.. 11.0-11.9 is what we usually try for at full boost to redline.
Your post went along fine with mine, so Im missing how you dont understand what I was saying. Youve had it for years, but not seen your a/fs drop WAY down after an install? Thats an instant loss in power if your boost level is the same. If you still dont beleive me, just take it to a dyno and do a before/after with same correction factors temp cooldown etc.
steve
NJ
I think what Ken is saying, is that once you install it of course you are going to increase the boost. It is going to enable you to make more power, even without doing a full tune on a dyno. Or, lets say you're running 20psi but you're getting knock. If installing WI eliminates the knock, you WILL start making more power without even changing anything else.
No it wont.
Im not trying to be argumentative with you guys. We all know lower A/Fs is less power, when you start raising boost or pulling fuel it makes your A/F higher/leaner. So when you install a W/I kit, (depending on kit/size/etc.) it could drop lets say 1 whole point in A/f, with less knock.
Now if you leaned it out with a AFC, to the same as previous A/F, it would be a little more power becauase of the cleaner higher flowing chambers and less knock.
But installing W/I and touching nothing after will net you less power. Thats my point, sorry if it sounds like im arguing with you. He didnt say if he was raising boost after, and Im unsure if he has a wideband or not, so my post was simply helpful info.
Polish
NE, IN
Well you are going to get argued with a lot if you keep saying it has to be dyno tuned. /ubbthreads/images/graemlins/rofl.gif
It's a losing battle, sorry. You don't need a dyno. There is nothing to tune. Install it and turn up the boost until it knocks the turn it back down a hair. No one in there right mind would install a WI kit and leave everything else the same, it would be like installing a MBC and not turning up the boost. Unless they were on the ragged edge and just used the WI to get things safe again.
Since you do work at a dyno could you post a before and after dyno chart of a Turbo car that lost power with a WI kit and the proper sized Jet installed. With nothing else changed of course. I am just curious what kind of cars are losing power with a Mod that makes the intake air colder. /ubbthreads/images/graemlins/confused.gif
steve
NJ
No it wont.
Way to quote only the part that serves you.
So tell me. Lets say I crank the 13g up to 20 lbs, and I start getting 43 counts of knock and timing gets pulled waaay back. Now I install water injection, which eliminates the knock, therefore timing doesn't get pulled. Its not going to make more power? Please. This is a bit exaggerated to make the point. I'm not saying you could run 20psi on a 13g with WI, but the principle is the point.
I was quoting the only part of what you said I was referring. Is that wrong? Jesus christ what is your deal?
Yes you would get less knock. But youre a/fs would be still lower so much that the power LOSS is more then the GAIN in knock reduction. Just trust me on that one. You dont gain a shitload of horsepower by reducing knock. You gain a shitload by a higher a/f, which is either A. turning up boost or B. leaning out with AFC (of course there are small factors like PnP that could as well but you get my point)
What if his boost is as high as it will go before hitting fuel cut, and his knock is bad and he has an extreme carbon build up problem? W/I could fix that, then use an AFC to add the extra fuel to compensate. Same boost.
Sure I could do that. Its more common in forced induction, as we have done a few Vipers and they had no power loss. A stock evo, sti, wrx, sr20det, srt4, etc. will lose hp just be installing. How is that point not getting through to you??? It lowers your A/Fs by alot. Do you not understand what im saying, or have you never tuned a car?
I should have ignored the rest after I read that. Im probably arguing with a 16 year old.
steve
NJ
Wow. You say in other threads "I don't know anything about DSMs" but you are making some bold statements here about tuning them and how they respond to knock, and how much power you lose when timing is pulled.
Polish
NE, IN
Then he is stupid. Fuel cut is easily overcome with a proper chip, you shouldn't be knocking at all, and carbon build up? Are you serious. Sure WI will clean it, but thats not what we are talking about. We are talking about your claim that a properly installed WI kit with the proper sze jet will lower power. I don't see this happening except in maybe very unusual circumstances. However like I said, Anyone who doesn't raise the boost after installing a kit just wasted there money. Unless of course they are a moron and were knocking to all hell before the kit and are finally doing it right, in which case they probably wouldn't touch the boost. Yes would make more power since the car wouldn't be knocking to death.
Just post the dyno sheet. /ubbthreads/images/graemlins/rolleyes.gif
Yeah I am 16, good one. Tough guy.
What is wrong with turning up the boost until it knocks then turning it back down. It may be old school but there is no other way to find out what the car will take. A count of knock or 2 isn't going to blow the car up anyway. You obviously have not been around DSM's long.
i know on the subaru forums that a person had there car tuned on pump with no knock and turned on the injection and lost power. If your car is properly tuned and then you add WI you will lose power. But on my subaru i had a rough tune and used WI for a day and the car seemed to love it. If your getting knock of course WI should help that, since your tune is most likly too aggressive
Polish
NE, IN
Did said person try different Jets, perhaps that one was to big if he didn't intend to up the boost.
ken inn
krum texas
in the early days of wi and the galant, my wi was not sophisticated, basically a pump, nozzle(s), and a hobbs switch. i was experimenting with things like what boost level, what size nozzle, nozzle placement, things like that. the stock intercooler/piping was still on the car. i even had an electric fan sucking air thru the intercooler. all i had was a jumptronix a/f, egt, and vac/boost gauge. mbc, still had stock injectors, fuel pump, yada,yada. the first few runs i had the wi coming in right at about 0-2 lbs boost, and the very first nozzle was way too big, when the wi came on, the motor started to bog. the effect on the a/f was astounding. .89-.9 before, then easy .99- when the wi hit. i would go down on nozzle size, and move the activiation to higher boost levels, i finally settled on 8 lbs, i forget what size nozzle, because then the car got like rre pipes, starquest, then rs, then rre griffin intercoolers. went 2 nozzles, then 1, then 2, etc. also got like a datalogger, afc, different turbo, etc. so, yah, too much wi will bog the motor, too soon has a similar effect, but not as pronounced. if you got knock, then eliminate it, that alone will increase power.
No there was no point. They did one run on the dyno to see what would happen and like the tuner thought they lost power. So they leaned it out and added more boost and most likly timing too. I'll do a search and see if i can find it for ya. IMO its not worth using just water. I like a 50/50 mix of water and meth thats where you can start to make some serious power without knock.
Polish
NE, IN
Ok so they increased the Boost, that works too. /ubbthreads/images/graemlins/cool.gif
However even on a stock car I'd bet the proper sized jet will show an increase in power.
I agree, running just water is cutting yourself short. You need to get into the fuel side if it to see all the benefits.
