V3 no start.
transparentdsm
Cherry Hill, NJ
I have dsmlink v3 on sd with a big 16g and evo8 injectors. I have done all the compensations for the sd and for my wb and my injectors. I followed the proper steps to make it run, but it won't. I can't get my car to turn on. It starts and then turns its self right off. I'm going crazy. I know my timing is good and that the car does run because i can use the 2g maf i have and everything is dead on and it sounds great. Then i turn it to sd and it wont stay on unless i peg the throttle and when i do that it spits at like 2400 rpms. Any help would be great. I really don't want to have to trailer it to a tuner and pay them to do it.
And you're sure the MAP and IAT sensors are connected *and* setup/saved correctly via ECMlink?
transparentdsm
Cherry Hill, NJ
yeah i double checked everything. thats why im going crazy... but i dont know this ecmlink thing well enough. so maybe i dont have everything set up properly. click here (and then click the download now button. it wont download just open another page)to look at the ecmlink setup i used to get my car started... maybe its old and there are things that have changed since this.
transparentdsm
Cherry Hill, NJ
when i got the car there was a 2g maf harness pigtailed in. i rewired it back to the 1g maf harness and when they spliced the wires they had the baro switch wire crossed with the other green and yellow wire. i had the car running with a 2g maf and a cel came on and it said baro switch malfunction, so i switched them around, thinking that could be the only thing wrong with it and low and behold vrooom the car started right up and ran perfect.
