Upgrading Dynamic4 to VR-4
bigandbad
Hamburg, Germany
Hello @ all...
I'm thinking about making a VR-4 out of my Dynamic4...
I saw many of yours are aprting out some cars - is there a real chance to get all parts together?
After studying ASA I noticed the only differences between both modells are -
- airfilter
- headers and turbo
- oilpan
- ECU
And, of cause, some internals at the engine.
I've a six-bolt 4G63 out of a n/a 1G Eclipse 2WD in spare, that I could upgrade with other rods and pistons - the only difference I could notice.
Any suggestions?
thomcasey
Indianapolis, IN
The transmissions are also different (weaker in the Dynamic 4) since your car is the equivalent of our GSX. You will want to look into a transmission with matching transfer case and rear-end. See this thread here
fuel
Toronto, ON, Canada
The Dynamic 4 brakes are also the smaller single piston 266mm/256mm (depending on year) up front. Rear discs are the same but rear brake caliper piston sizes differ between early and late models.
