Turbo for my 2.2l build!
89jvr4
Member
sydney,nsw australia
Hey everyone, I'm currently in the process of building my 1990 rs galant. I plan on making 600whp or more with room to go even further if it is needed, it will be on e85 and have a built auto to take the abuse. I'm just having a hard time with what turbo i should run ? I currently have a t3 manifold with a 40mm turbosmart compgate so it would have to be a t3 housing. I was looking at turbo labs 67mm hx40 with the t3 .82 housing, but also had been recommended a 6266 or garret gen2 gtx3584rs. Im open to any recommendations. TIA
Current modifications to the motor are:
Eagle 94mm crank
eagle h beam rods
86mm cp 2.2l stroker pistons(9.1cr)
kelford tx280r cams
kelford btk titanium retainers and valve springs
Main girdle
arp everything
head service
tektic
ronkonkoma, ny
I have the same bottom end but Manley pistons . I’m using a s16g and GSc s1 cams. It boosts so fast. I’m not great with non Mitsubishi Turbo’s but anything that is bigger than a 20g should get you right around your goal. I’ve driven a 6266 car with bc 280 cams. It was really just good for drag racing. Stock engine big turbo and front mount on sd. It was 500hp at 5k but 160 anywhere below. I didn’t like driving it.
