littleb
So as the title says, I'm trying to make an s362 fit. I'm having trouble even getting it to fit on to the engine itself. I have a JMFab top mount manifold and the turbo is hitting the head. I already ground down the parting like on the turbine housing and it's still hitting. So my plan was to get a spacer that was maybe 5-7mm but all I can find are exhaust manifold flanges that are about 1/2" thick. There already isn't going to be much room in the engine bay before having to put a spacer but there is absolutely no way that I can keep my stock radiator with a spacer. So what is your guys favorite radiator and fans? The two radiators I'm looking at are 1g and scirocco. Obviously the 1g would be the cheaper route to go but is the scirocco radiator that much better? I don't know if I'll be able to use pull fans either so I may need to use pushers. Any recommendations on that? Thanks
