Trouble Starting After injector change
jmorri15
Kemp, TX
I attached two different logs, one if from a few months ago when i had rc550's installed i took the car a mile to go get a tank of gas. the other is from trying to start the car today. Heres the list of modifications i have on the car.
2.3L
272 regrinds
255lph fuel pump
fic 850cc
SD setup running through link
greddy18g(now 20g)
larger front mount
external oil cooler
afpr
the only thing i changed between the last log and this one i had to change out a cam gear and i put in the 850's.
so heres the questions
first i dont know why my iat sensor is showing neg 40
also why wont it start, it should just start right up according to what ive read.
Link to Logs
JNR
ca
FIC's sit a little different than others, most notably Densos and the rail spacers *should* be trimmed down a bit to have them seal properly; that and of course different o-rings. Least this was my experience when I had FIC's from the denso's (went back to densos again but larger) and measuring the two, etc. Most people don't do this and guess they don't have too many issues, but an FYI to do things the right way (if you look/measure the two side by side, you'd see what I mean). I would think it's possible to have a leak at the head that is just enough to get air by, but not fuel, but just sort of guessing there.
