Transmission Problems.............
turbomcc
Active member
San Antonio,Texas
I have upgraded my transmission with double syncros and a welded diff..........My problem is that when i am at the track and i shift from 2nd to third,i either brake the fork or the shift rail on the3-4 shift rod.......Everything is new from Mitsu. cables,bushings and brackets.Is it possible when i go from second to third that i could be hitting the shifter to hard when i go up a gear?????
