transmission and mount bracket questions
Kentstatetsi
Active member
Savannah, Ga.
doing a trans swap because it was popping out of 1st and 4th. I have 4 extras so no big deal on that. The mount bracket I was using was stamped 22-H. I found a bracket stamped 210H in my garage that is slightly different but both mount to 1g transmissions. Which one is correct? I've searched the factory part #md731017 with no luck on finding a picture of the stamped part.
All 4 of my spares are NPXV's but 1 has a different center case on it where the mount bracket goes. I was guessing its from an early 2g but it doesn't have the counterweight on the shift levers.
tektic
ronkonkoma, ny
My 1g fwd manual has a 200h bracket.
The 22h I have is from an awd manual 1g
22h is from a vr4 as well?
89Mirageman
Stantonsburg, NC
Is your 1g fwd a turbo car? Every 1g fwd turbo dsm I've ever seen with a manual trans had a 210-H mount. 200-H is new to me. Pretty sure the 22-H is for a GVR4 too although I'm not positive.
