Transfer case recall kit part number request
fuel
Toronto, ON, Canada
Hey guys, apologies if this is a repost but couldn't find what I was after using the search function.
It's now *my* turn to ask for a part number from you guys! Mitsubishi NZ do not have any records of the transfer case recall kit, which I understand is actually cheaper to purchase than buying the front driveshaft yolk separately. If anyone could let me know what the part number is for the kit that would be greatly appreciated. Thank you!
fuel
Toronto, ON, Canada
what does the kit come with? Through Mitsubishi NZ the recall kit is actually about $10 more expensive than the yoke itself, which alone is about NZ$140. I already have the transfer case seal itself so if the kit comes with just the yoke and the seal then I am better off buying just the yoke. Thanks!
Vman911
Douglas county, Ga
you just need the yoke kit. Theres a freeze plug like thing in very back of yoke and it causes the leak. I just did mine and my dads and no more leaks out of transfer case.
MR470072 is 36.00 at www.rchillmitsubshi.com. I just got 2 in the mail last month. took about an hr to do it.
can this be done while it is on the car without removing the transfer case?
fuel
Toronto, ON, Canada
^^ yeah transfer case stays in place you just gotta pry the seal out the back and remove the driveshaft to replace the front universal joint.
fuel
Toronto, ON, Canada
Quoting Vman911:
Also thanks for that! Have just placed an order with them. Saved about $60 ordering from them as opposed to getting it locally. It cost just as much in shipping to NZ as it did for the part itself!
fuel
Toronto, ON, Canada
Ok so MR470072 turned up in the mail from RC Hill Mitsubishi, but it appears to be missing the transfer case tail shaft seal! I thought this kit was meant to come with the seal? It came with a bunch of circlips but no seal. I don't mind that it's missing the seal as I'm pretty sure I already have two seals spare as it is, but I just thought I would confirm with others that it was meant to come with the seal?
Thanks
I couldn't tell if the seal came with it or not so I decided just to order the seal itself along with the recall kit. It was $5 extra from mitsuishiparts.net
