Trans info
mitsu90
Illinois
I picked up a 5 speed trans and Tcase for $25. The guy bought it used and knows nothing about it. Is there any way to check if it's good? I know "when in doubt rebuild" However the trans in my car is crapped and I would like to send the better on the two to be rebuilt .
SmoothCustomer
Lexington, KY
You should be able to put it in all the gears with the shift forks that are on top of the transmission. You can use your car if the trans is still in as a reference for what each gear should look like. I'm sure there are other ways but that is a simple preliminary way. If that doesn't work, it's got problems.
mitsu90
Illinois
I shifts be hand fine..But I wasn't sure if that meant squat /ubbthreads/images/graemlins/idea.gif
jepherz
KC, Missouri
There isn't going to be much you can test outside of putting it in every gear and checking input/output shaft rotation. Once you get it in the car, you'll find how well the syncros are working, and if the center diff is good or not.
Cheap find! Are you sure it is the right gear ratio? (from a AWD turbo DSM?)
mitsu90
Illinois
Yea it's out of a DSM.. The tcase has 91 galant VR4 wrote on it with a paint pen.
/ubbthreads/images/graemlins/idea.gifOhhh! The paint pen method. Very reliable method. /ubbthreads/images/graemlins/uhh.gif
What numbers are stamped on the tranny?
mitsu90
Illinois
Not sure I haven't looked that far into it. I was more amused that it said galant on it then anything. /ubbthreads/images/graemlins/dunno.gif
mitsu90
Illinois
Quoting Dbossman:
kw5m332npxv
mv5008
