Tires
2of9
IGH, MN
Well...I'm deciding to put the 50 sidewall rating on my stock 15s or the 55 sidewall rating tires. For some reason, I looked around and the 50s were cheaper than the 55s. The size I'm looking for is 205/50-15. I dont want the 50s on my 15s looking like 45s too, but i want the 50s. Does anyone have pics of the whole car with some 55 or 50 sidewall rating tires on the stock rim? thanks! What have you guys put on for the stock rims? or do you guys just have some aftermarket rims on? Any tires you guys could suggest? thanks!!
I would reccomend a seven inch wide wheel for a 50 series 205. the bigger problem is your car will look like a fat chick with her skirt hiked up on 50/15's.
A 205 55 or 60 would look better. make sure to check with the manufacturer of the tire you want & see what the reccomended rim width is before you buy.
too wide a tire on too narrow a rim will cause the car to float from sidewall to sidewall during transitions & reduce handling.
Edit: BTW this type of topic should be in the newbies section.
I have 205/50/15 on the stock wheels on 115 (previous owner). they are too small both in overall diameter and performance on this heavy car for me to ever do it again. 205/55/15 may be ok and closer to stock diameter, but I have not tried it. I will go back to stock size or one larger at 205/60/15 likely.
gvr4ever
central Indiana
I've been running 205-55-15s for years. IMO, it's the best size for the stock rim. Also, you can still get some good performers in that size.
I'd go for at least a 55 sidewall on the stock 15 in. rims, and 205 is about the most width you should put on a 6" wide wheel.
For comparison my car is riding on 205/50/R16 on 7" wide wheels. Next time I'll go 215/50/16.
TWEAKD4
Fort Wayne, IN
Qship. Just go with 225/50/16. It is more common of a size and wider contact patch. I have been running it for years. Just a tad larger than stock tire diameter.
I suggest going 205/55/15 or 205/60/15. Look at www.tirerack.com and look at the diameter of tires you are looking at. You want to be as close to stock diameter as possible. 205/50/15 is just to small and look very funny unless you have lowering springs. Running smaller tires will mess up your gear ratios as well.
