ercp98
so i followed the vfaq way of setting the timing in the gvr4. i have it set at 5 degrees. all is ok while i set it using the timing light. i grounded the line attached to the firewall.also i took oout the logger while i was setting the timing. now why is it that my logger is showing (TMA) 8-10 degrees while at idle?
