timing gears
hey guys this should be the last ? im really sorry to bother you im putting this motor together and the cams did not have the gears installed. jw if the gears are the same or is there is a intake and exhast cam gear. Thanks in advance almost finished and she should fire as long as there are no underlaying issues i did not address
Hertz
Chicago, IL
edit: the gears are the same, the timing marks are different. I'll let someone who has actually built a motor answer this.
cspetros
Port Norfolk, VA
Also note that there are dowel pins that aid in the alignment of the gears (rather, sprockets; Wop). Good luck /ubbthreads/images/graemlins/smile.gif
galant412
Traverse City , MI
As long the dowel pins are up and not down and the timeing markes are on the front of them but. Im sure that some one put whiet pant on the marks that you need.
