timing belt adjuster
where do you order your auto adjuster from? mine went bad and the timing belt went loose so i figured i might as well get it over with. im looking to get the new adjuster and replace the belt. should i get all the pulleys as well or just the belt and adjuster? if anyone has a link to where i can order one that will help a lot.
Terry Posten
Davenport, Iowa USA
If you want OEM, call JNZtuning.net
If you want aftermarket, call Partsdinosaur.com (they claim it is the same as OEM and it does look like it)
I have used both on cars I have built and I have never had a failure.
