Throttle body new question
mcbride89
Belmar,NJ
I know some differences in TB between 1 and 2g is size 60vs 52mm. I have 2 spares of each. This is obviously a 1g and I measured it with my veneer and it's 60mm but my question is the 4 ports on top. This one has 3 and the 4th casted there but nothing there.
Question is, can I use this? On my other TB they're all blocked off anyway.
I just plan to clean and rebuild it and block the FIAV
Ant
desant78
Clarksboro, NJ
Dont use them!! Apparently they designed for emissions, and i had massive issues using them for a boost/vaccuum. One only produced boost and it was all wierd.
A trusted member told me the emission info, and it solved my fpr and boost issues. So i cant promise the info, but i advise against from using it.
mitsuturbo
Near Seattle, Washington
How does one measure with "veneer" ?
That is a throttle body off a naturally aspirated vehicle. AFAIK they work just fine, but replacing the shaft seals is highly recommended.
raptorWagon
Oak Harbor, WA
Quoting desant78:
Sounds like your experience involved using throttle bodies that needed to be rebuilt in the first place. NT shaft seals aren't exactly made to handle boost or probably a lot of boost and would probably explain your issues.
