Tension accessory belt
veganbutcher
Just re-installed the power steering pump and it needs to be tensioned. Does anyone have a diagram showing where the tensioner pulley is? Also whats a good way of making sure you have the correct tension without a calibration tool.
EHmotorsports
Beaverton
There are no tensioner pulleys for the PS. There are slots where the ps pump bolts to the bracket. 1/4 movement of the belt is plenty of tension.
There are two top bolts. You can probably get away with only using the one that's not stripped. Maybe...
veganbutcher
Quoting turbowop:
Crap, I lied. There aren't two upper bolts, there are only two lower bolts. Sorry.
Lol that's what I thought, I was also considering using a nut on the other end of the PS pump but there isn't enough clearance for that.
