belize1334
I'm having the same clunking noises that were reported in this thread about Hot-Bits.
I'm using Bilstein struts w/ DIY coil-overs and the problem I'm having is that the spherical bearing articulates nicely but it doesn't spin very easily. As such, when I turn the wheel the spherical bearing doesn't rotate very much and instead the strut piston rotates as does the spring perch. But since the spring itself is fixed with the strut, I get a popping sound as the spring slips on the upper perch. It only happens on the drivers side and I was VERY careful to install in such a way that the bearing is properly shimmed and there is no load on the housing (which might cause the strut/perch to bind and shear).
I spoke to Tein and they said that I have to send it in and they'll do it for $60 per side. But, I expected them to say something like that and I'm wondering if it isn't possible to have it done locally by a competent machinist. Has anybody pulled these apart? Can they be disassembled and serviced?
