TB leaking
971of1000
joplin, mo
I am running a 1g nt throttle body on the galant and ran a boost leak tesr yesterday and am leaking out of the shaft seals. my local mitsu dealership said it is not servicable and i was wondering if anyone knew where to get these seals.
TylerAdamson
Iowa City, Iowa
I'm currently rebuilding a non-turbo throttle body for 934 and ran into the same problem. I researched it a bit and nobody makes shaft seals for the non-turbo throttle body. I then however found that if you're careful when tightening the nuts on the throttle body you can use the turbo shaft seals that JNZ sells.
