Talon to galant parts.
JackstandTSi
Columbus Ohio
Ive been trying to sell my Talon so i can get my galant up and running, What can all be used from a 92 Eagle TSI FWD on my 92 GVR4. things like power steering pump and lines, would the timing belt tension/pulleys work. Its a 1g 7bolt block in my Talon.
5OF2k
colorado springs, colorado
The steering pump lines brackets and rack can be used, but only if youre deleting the 4ws on the gvr4. The timing components will not, unless you have a 7bolt swapped into the car, with the exception of the idler and tensioner bearings, IIRC.
Hope that helps.
-Jake
