T-stat wiring help
dsm10o0
San Jose CA
Hi, just got my galant and this is my first one. I wiring needs help and I'm changing out the crusty old broken wires and connectors. They were all cut and I don't know where they go.
Colors of wires I need to find.
2 wires = green/black and green/red
1 wire = blue (coolant temp sensor?)
1 wire = yello/red
2 wires yello/green
Thanks for the help.
Struc
Oconomowoc, WI
A little searching is a good thing. I've posted this at least 5 times already.
Blue/Black, single wire sensor, A/C Condenser Fan, Normally open
Green/Red and Green/Black, 2 wire sensor, A/C Clutch lockout, Normally closed
Green/Black and Yellow/Green, 2 wire sensor, ECU Temperature sensor, variable ohm reading
Yellow/Green, single wire sensor, Cluster temp gauge, variable ohm reading.
dsm10o0
San Jose CA
Last question, where does the other single wire? 2 wire on top, 2 wires on bottom, 1 for the temp sensor, then the other?
