suspension bushing
presterone
brunswick maine
Im not sure exactly what to call this part it makes it different to find a replacement. I have a seized toe adjuster for the passenger side rear. It is a trailing arm I think that is also the rear hub/wheel bearing housing assembly. Anyway I need to cut out the bolt and replace the adjuster and bushing. Do I have any options on deleting this positive rear toe setup, I saw some spherical helm joint type adjusters on the Vfaq but I was unsure if they were replacing this bushing. And if I am going to just replace the bushing where should I look? I tried whiteline and JNZ tuning
presterone
brunswick maine
Okay so you cut off that eyelet that houses the bushing and weld on the eliminator kit? can you adjust rear toe with that kit?
LIV4PSI
O-H-I-O
Quoting feil8409:
JNZ active toe eliminator kit. Replaces the bushing with a weld in insert and a rod end.
Although JNZ does sell the kit, it is actually a Jay Racing toe eliminator kit. Heat the old rubber bushing, and get it out. Don't cut it, it slides into the trailing arm.
Here is to JNZ to buy said product
JNZ Tuning
And here is the Jafro approved install instructions.
Jafro Youtube install instructions
presterone
brunswick maine
Noiiice!!! trying to figure out if this will be good for more than dragracing or if I should just get new replacement bushings. Thanks dude for your help
LIV4PSI
O-H-I-O
If you decide to go with replacement bushings, I have some Energy Suspensions ones. I bought the master kit for my car, but I ended up using the Jay Racing kit, so I don't need those bushings. I am a top rated seller on ebay. Help fund my build /ubbthreads/images/graemlins/devil.gif
My opinion is the toe eliminator kit helps more than just with drag racing. The stock active toe causes understeer when a load is applied. There are other ways to help deal with the active toe though. The stock rear steering rack helps, or there are braces that replace the rack if you no longer have 4WS.
