stupid questions
kkmcgregor
Active member
Lexington, Kentucky
I have 2 quick questions
1. Does anybody know what flange is on the fp dsm exhaust manifold?
2. I have an autometer oil pressure guage that worked fine until my batter died now it won't work. Light still works wires seem fine can't find any blown fuses. Any ideas?
Thanks for amy help
1. It's called the "DSM" flange.
2. Faulty wiring, or a bad gauge. Start checking for power and ground at the gauge on the appropriate terminals.
kkmcgregor
Active member
Lexington, Kentucky
So what would the gasket be that I need between the mani and turbo? And thank you for your answers I'll recheck the wiring to see if I missed anything.
kkmcgregor
Active member
Lexington, Kentucky
Neither I have a garrett 3071r internals in an unknown housing that's why I asked about the manifold since I assume there's only one flange for it
The 7cm gasket should work fine, assuming your mystery housing bolts up to the DSM flange.
