Stock / Lowering/ and Coil over sleeveSpring Combo?
711
Active member
Neverland
Hey guys just a quick question.
Anybody here tried a stock / lowering spring combo in the front and ebay coil over sleeves in the rear?
It's like you can have a nose down height with the rear heightened or normal height.
Also, when there is a need for a full load in the rear then you increase the height.
Anyone? your thoughts? /ubbthreads/images/graemlins/dunno.gif
Thanks!
tektic
ronkonkoma, ny
Sonds like it will be uneven.
EBay springs ar usually not good quality and do not specify strength of the spring they are selling so its anybodys guess what your actually getting.
Changes in ride height will change camber, so your tires ware will suffer.
boostback
Active member
Bossier City LA
ive never had good luck with the slip on coil overs. had one bust out on my civic hatch about a month after i bought it.
