Stock 14B turbo connector pipe
JAP_GVR4
New member
Fremont, NE
I recently acquired #537/1000, the previous owner put an ebay turbo and exhaust manifold. I took those off in the attempt to replace with better quality items. Ive spent the last several months gathering and collecting pieces. Almost have everything together to hear her breathe again, but the issue I am currently trying to solve, with no luck, is the turbo connector pipe, the little 3 inch-ish pipe that DSM guys generally refer to as the 'j' pipe. I want to keep stock radiator fan and the turbo I purchased is a factory Mitsu turbo from a low mileage 1G Eclipse. however the connector pipe I received with the turbo throws into the stock radiator fan. I need a connector pipe to go over the exhaust manifold, does anyone make such a piece or am I searching in vain??
thank you Jake
Sounds like you just need the stock GVR4 turbo outlet pipe. It is different than the 1g Eclipse version. Someone here should have one. Post a WTB.
I'm sure there are some, but as noted in your other posts, if you are looking to keep it stock, get a stock one. Aftermarket will probably charge you $40 for an inferior piece.
