Speed density and IAT sensor wiring assistance
TX1853
New member
Dallas
Hello. I am converting to speed density on my galant. However I am finding little to no info on wiring installation. Most likely as I am running aem ems v1. This is what I have to work with for now. Cant spend the money for link at this time. I have done a speed density setup on my 1g but I have not done a galant before. Just need assistance in how/where to wire in my gm style map sensor and gm IAT sensor. Thank you.
Eztoril
Irvine CA
Here you go. Contact user "iceman" he may be able to make you an adapter. There shouldn't be much if any difference on a 1g or vr4 setup. Have him make you a pigtail with only the wires you need and you can wire them to your sensors.
SD wiring
raptorWagon
Oak Harbor, WA
Yeah you can just get either the maft sd adapter harness or the adapter harness off ecmlink's website. The aem ecu isn't a bad way to go either.
TX1853
New member
Dallas
Thank you estoril and raptor wagon for your assistance. My maf plug is missing so I need to just wire everything in directly. Thank you for the provided link! I have now figured out how to wire everything in thanks again /ubbthreads/images/graemlins/applause.gif
