sourcing parts
mountaineerjeff
west virginia
Hey guys I havent had a chance to work on my car in a really long time, so I kinda fell out of the loop. im gonna post a similiar ad in the wtb section, but i figured id start here for help.
I am gonna be making my own exhaust and intercooler setup and all I have is straight tubing,all sizes, welding equipment and a lift.
exhaust
I need a 16g flange to start with, then I want to disable the factory wg,
so I need an aftermarket wastegate, something that will be accurate up to 20-25 psi, im only running 10-15, but id like to be able to step-up
the wastegate also has to be able to fit in the general location of the o2 housing
Id need the WG flanges in and out, unless I went with a Vband setup which would be alot nicer
I need a 3" mandrel bent 90 degree peice of pipe, I only have a pipe bender.
also how expensive are vbands? id like to vband the DP so Id only need 2 3" one unless id did the WG as well then Id need one more
intercooler
I have a evo 8 intercooler and a 1g Blowoff valve so I need to find some 2.5" bends, I found that generic kit on ebay, but Id have to source connecters
My roomate is also doing a vband set up he found a set on ebay for im thinking 20 bucks shipped.
**edit just talked with him it was 28 shipped came with 2 mild steel v band flanges and a stainless clamp..
also LMK and 89mirageman can help to for parts /ubbthreads/images/graemlins/smile.gif
