SOLD: Rust Free 1079/2000 Summit White Galant VR4 in MA $6000
turbophein
mass
$6000 FIRM
the body is Rust Free with only 1 small ding that can be easily pulled.
148k
Engine:
•2.0 0.40 over Arias pistons, balanced and blueprinted with balance shafts removed and ARP head studs.
•Comp Cams 272's
•Head rebuild with new valves, seats, guides and Gen 3 lifters
•BC Springs and Ti Reatiners
•EVO metal head gasket
•New timing belt, tensioner and idler pulley
•New water pump
•All new seals and gaskets
•PTE 1000’s injectors
•Walbro 225 fuel pump
•Auto Meter Boost, LC2 wide-band O2 and Auto Meter Oil pressure gauges.
•AC kept with new compressor. System needs to be charged and belt reinstalled.
Turbo
•New Forced Performance EVO 16G
•Ported and hot jet coated manifold and turbo exhaust housing
•SS 2.5” turbo back exhaust
•Manual boost controller
•Big front mount 24x12x3 with custom 2.5” IC piping
•Running Speed Density
Suspension
•AGX struts with Ground Control coilovers
•Ground control front camber plates
•Ingalls rear camber kit
•Urethane bushings throughout
•Front strut tower bar
•22mm rear sway bar
Drive train
•ACT 2100
•4 bolt LSD rear differential
•Resurfaced flywheel
•New driveshaft carrier bearings and CV joints
•1.8 Manual steering rack
•New tire rod ends and lower ball joints
•Slotted and cross drilled rotors and SS brake lines all around
Miscellaneous
•DSM Link V3
•Rear steering removed
•JDM clear marker lights
•Battery relocated to truck
•17x7 konig Imagine wheels with Yokohama 215/45/17. Tires worn on the inside due to old rack and pinion replaced with 1.8 manual rack and pinion.
•New front and rear wind screens
•Alpine head unit and four channel amp
•10” bazzoka tube in trunk
•Rockford Fosgate cabin speakers
Interior is very good with no tears in leather. Overall car is in great condition, however needs someone willing to put the time into performance tuning and working out any bugs. tranny was rebuilt and is solid but tough to shift sometimes, never had a chance to look into it, i doubt i put 500 miles on the car.. No longer have the time. car is pushing 16psi with a safe tune and pulls hard. car has well over $20k in receipts that come with it.
Body was Completely repainted the right way. also the entire undercoating was removed and recoated along with the rear subframe, the car is Rust Free! here is the link click
car is in Dartouth Ma at a friends house, i just moved on the first and no longer have a garage to keep this beauty safe nor do i have off street parking, its been garage stored for the last 8+ years from previous owner with no winter driving, i would like it to stay that way
4orced4door
Raleigh, NC
This car looks like it's been done right. I really like what you did with the undercarriage coating. I haven't seen a VR4 I've wanted to buy in a while, but if I were in the market I'd be on this one. Totally reasonable price. Good luck with the sale! (and you might want to add some more pictures)
4G63_GSR
wis
Yes we need more pictures. This car makes me want to sell my 2gb talon, not worry about emissions, and have a back seat for the kids.
ShaggyTE
Omaha, NE
Quoting KT:
Hey Shaggy, let me know if you need a road trip buddy!
If I buy it, I'm trying to time it when my wife goes to VT at the end of the month and I would just fly out the same time and then drive up to meet her. I appreciate the offer though!
ShaggyTE
Omaha, NE
No worries, I definitely plan to! Even though Matt doesn't plan to frequent the forum as much now, he was awesome to work with as an fyi for everyone else
KT
Omaha, NE
I think that means we'll have one of each color in Omaha now!
