SOLD: Denso Supra Twin Turbo fuel pump
CO VR4
Colorado
SOLD SOLD SOLD SOLD SOLD SOLD
I'm cleaning the garage, and found a OEM Denso Supra Twin Turbo fuel pump, in good working condition, with the fuel sock, that I'd forgotten I had. So here it is, for sale. I just tested it 5 minutes ago.
This is a critical element to making sure that you don't run lean when you start turning up the boost. The Supra pump has the advantages of being Original Equipment Manufacturer quality, is QUIET (as opposed to a Whinebro) and dead reliable. It will provide enough fuel for up to 450 HP, if it is wired to adequate voltage.
The flow specifications are:
Denso 260 LPH Supra Pump, Denso part number 195130-1020
Volts PSI Amps Flow(LPH)
43 15 258.04
12.5 volts 58 16 227.13
73 18 190.54
43 17 296.53
14 volts 58 19 270.03
73 21 239.75
First come, first served. Paypal, add 3%. Thanks, all.
