I'm moving from Maryland to California, and I have way too much sh*t. I need this stuff gone, and am out of time to box, ship and dick with selling individual items. $100 bucks, and the whole lot is yours if:
1) You give me $100 bucks
2) You take EVERYTHING
3) You pick up
Keep what you want, and junk or resell the rest. I don't care. I just need this stuff gone, as I can't move it, and would like some of it to get put to use. Below is a list of what's there, and there is probably some stuff I forgot. As I continue to clean out the garage the pile will probably grow.
Parts are located in 21638. Message me for specific details regarding pickup.
In the pile is:
- Two 1G AWD rear dust shields
- OBX Racing adjustable cam gears
- GVR4 front ABS rings
- Complete 1990 DSM intake manifold with coil pack, throttle body, elbow and support brackets
- 1G 91+ intake manifold with support bracket
- Random thermostat housing parts
- Assortment of pocket logger cables and a Palm 3C. Palm won't power up, probably needs a battery.
- 1g KYB AGX suspension with H&R springs. Struts unknown condition. I believe the springs have been cut as well.
- NIB Air Hog air filter for a 1G DSM
- Flexable brake lines for a GVR4/DSM
- Cheap catch can
- 1G DSM EGR valve
- Two DSM brake reservoirs
- Stock 6 bolt flywheel
- Two stock DSM O2 housings
- Random A/C brackets
- Randon engine brackets
- 346 engine mount brackets
- Stock 1g AWD center diff
- 1990 Turbo/FWD ECU, non-EPROM Part # MD128625. Caps are stock, no leaking visible. Board looks mint.
- 1990 stock oil coolers and parts
- B&M oil cooler. Fittings leaked.
- Stock GVR4 power steering cooler
- Random starter plates (not for AWD 1G DSMs...FWD maybe?)
- Ream main seal plate
- A/C compressor (unk car)
- Harmonic balancer for a 6 bolt
- Two clutch master cylinders
- Random turbo feed, coolant and drain lines
- Two oil dipsticks/tubes for a 1G DSM
- Water pipe in rough shape
- Timing gear
- Toasted balance shafts (good for installing BSE bearings)
- Power steering bracket w/ heat shield
- Water cooled Oil filter housing
- GVR4 stock intercooler
- DSM cooling fan motor
- Evo 3 GAB front strut bar (might work on a DSM, not sure)
- GVR4 Hood prop rod
- Assorted GVR4 4WS lines in good shape
- Known good GVR4 rear steering rack
- Unknown condition starter
- Rear control arms for a 1G AWD
- Unknown shifter base
- 3 bolt rear end (case only, for parts/rebuild)
- Unknown 2.5" downpipe
- Lot of Centerforce/ACT clutch discs and pressure plates
- 501 MAF with intake adapter
- Stock 1G MAF with trimmed air can and ugly K&N filter
- Galant VR-4 HKS air box. Also comes with a custom plate to run a 2G MAF if desired
Water pipe. Mounting tab broken, rough shape. $15 shipped.
3) You pick up
In the pile is:
- Cheap catch can
- 1G DSM EGR valve
- Timing gear
