Okay I will try to be as detailed as i possibly can.
91 VR-4, #1902
Green
185k miles
Body:
faded paint, no clear left
front bumper broken near fog lights and hangs off on drivers side near fender.
rust bubble on front edge of hood approx. 3"x3"
small dents n dings
underside, other than typical road grime and oils is okay
trunk opens sometimes, lock messed up
antenna does not retrack completely
rear quarter panel has slight push
rear pillar has body filler (see pic) and has started to come out
sunroof - does not leak, works well
no windows leak
windshield, no cracks, but is wiper scratched pretty bad
new bosch icon wipers
Interior:
a/c all there but does not work
all functions work except the rear defroster
MOMO steering wheel
1g shifter assembly
badge #1902
carpet fair, had it our and pressure washed it, drivers side foot pad is out
all components there
chrome chipped on passenger side door handle
seats in pretty decent shape, no tears, minor wear and all functions work
headliner ok, little dirty
pioneer headunit
Engine and mechanical components:
engine uses oil (surprise)
typical lifter noise (surprise)
magnecore wires
2nd gen manifold/ o2 housing
16g - VERY NEW!
manual boost controller
Car will have STOCK EXHAUST
good battery
Tranny shifts great, stock clutch
Super AFC
VDO boost gauge
Apex turbo timer
255lph pump in tank
ABS doesnt function properly, i think due to a bad sensor that i cannot get out, ABS is currently unplugged. (braking is fine but will need addressed)
needs front rotors
has new front pads (on old rotors unfortunately)
new replacemnts front stuts
new ball joints
need lower control arm bushings replaced, suspension bangs around over bumps
DRIVESHAFT needs rebuilt has horrible shake with acceleration that is too fast. (this recently occured...havent had time to rebuild it)
tires are fair
I think i pretty much hit on all the good and bad i can think of. Feel free to ask questions. Im in Hanover, Pa 17331. Car has to go asap.
I HAVE 10 PICTURES OF THIS CAR THAT FOR SOME REASON I CANNOT UPLOAD. EMAIL ME AND I WILL SEND YOU THOSE IMMEDIATELY. (sorry, i tried to get them on here)
Kevin
[email protected]
717-465-0773
91 VR-4, #1902
Green
185k miles
Body:
small dents n dings
no windows leak
Interior:
MOMO steering wheel
1g shifter assembly
badge #1902
pioneer headunit
magnecore wires
16g - VERY NEW!
good battery
Super AFC
VDO boost gauge
Apex turbo timer
255lph pump in tank
needs front rotors
new ball joints
tires are fair
Kevin
[email protected]
717-465-0773
