Purchased this car from Garfield in Florida about 2.5 years ago.
Car is running but not drivable at this point in time. After replacing the transmission and driving it home it sat for about 8 months. Now it has trouble starting.
JDM rs hood, paint is Belize green as well, some sun fade.
JDM side-markers, When replacing a bulb, the inside of one cracked. I bought a set of Super clean U.S edition ones, still in the boxes they came in.
Exhaust all the way back from what i can tell.
17 in wheels with Hankook tires. Recently put one brand new one on due to dry rot, may replace another.
Autometer boost and oil psi gauges.
JDM motor, transmission that came with the car lasted all of a few hundred miles so it has been replaced.
16g turbo,waste-gate rod seems to be stuck so it runs high boost.
2g mas and intake
ACT 2600 Clutch, Entire clutch pedal assembly REBUILT, NEW clutch master, NEW slave.
Good compression on all cylinders.
Brand new rear brake pads, Rotors, Calipers(Caliper heat paint installed on calipers) and brake lines. Very costly for this car..
Turbo Timer installed.
KYB AGX installed all the way around.
FMIC from a mk3 supra installed.
I also have an ECU a forum member made and chipped for this car, setup for the 16g, 2g mas ETC that i may include with the car or sell outright.
Ive got around 5,000 in the car plus parts. I believe i have receipts for all of this as well.
I am open to trades, just shoot me some info. Id like to get 2500 out of the car. I took some pictures after i waxed it a little today, they will be uploaded tomorrow.
Thanks for looking and give me a shout for any info you need,
Jet
The red dots on the windows are just window chalk, for Halloween some roommates did it.. Heh.. will most definitely be gone by the time somebody sees it in person.
2g mas and intake
Jet
