SOLD 138/2000 Klamath Falls, Or 12K$ SOLD
transparentdsm
Cherry Hill, NJ
My Jenny-dog is sick. I need to make sure i have money in my savings for anything that can happen. i won't know for about a month if the drugs are going to help her, so if this can be sold ill let it go. Willing to take a turbo automatic only(FWD or AWD) as a partial trade as i will need a car and Cait and i will be sharing as were selling her car to.
willing to remove harness bar, coilovers, turbo, intake manifold, BOV and throttle body, put the stock parts back on and reduce the price 2000$
car currently has 210,xxx miles
Everything was done on the car at 183,642 miles unless otherwise noted.
Engine:
2g pistons/1g rods
evo 8 valves, springs & retainers
MLS head gasket
arp head studs re-torqued at - 207,321 miles
revised 3mm lifters - 186,231 miles
BSE Kit
Forward facing oil filter housing
Unorthodox Aluminum Crank Pulley - 194,543
Prothane Red Motor Mounts
HKS Clear Timing Cover
Mishimoto catch can - 207,321 miles
Black Top CAS - 202,136 miles
SS oil feed line - 207,321 miles
Larger oil return line - 207,321 miles
Custom water pipe - 207,321 miles
SS valve cover bolts - 207,321 miles
BC 272 Camshafts - 210,000 miles
Fuel & Ignition:
Custom trunk battery tray - 202,231 miles
D-51 series Optima Yellowtop - 201,642 miles
AEM 340 in tank fuel pump - 202,136 miles
Fuel pump re-wire
denso 780cc injectors
Injector seals and cleaning - 207,321 miles
full throttle FPR w/ gauge
-6 AN line from filter to rail - 207,321 miles
Russell Fuel filter - 207,321 miles
NGK Copper BPR8ES - 207,321 miles
SS fuel rail bolts - 207,321 miles
92 octane
Intake & Exhaust:
Ported Evo 3 exhaust manifold - 207,321 miles
Exhaust manifold studs - 207,321 miles
PTE SCM 6152E - 210,000 miles
ARP manifold to turbo bolts - 207,321 miles
3" intake - 207,321 miles
Punishment racing EW with Tial WG - 207,321 miles
Titanium Heat wrapped down pipe - 207,321 miles
3" turbo back exhaust, W/ V-Band clamps, Vibrant muffler - 207,321 miles
JM Fabrications SMIM - 210,000 miles
Thermal throttle body and intake manifold gaskets - 207,321 miles
1G ETS race intercooler - 207,321 miles
Tial 50mm BOV - 207,321 miles
2.5" aluminum intercooler piping made to be as short as possible
GM IAT
OMNI 4 bar MAP sensor
IR boost controller(linked into ECMLink)
S90 3" throttle body - 210,000 miles
FIAV block off - 191,943 miles
New Biss with o-ring
all new gaskets - 207,321 miles
full OEM heat shields - 207,321 miles
Misc. SS bolts - 207,321 miles
Drivetrain:
short throw shifter
Rebuilt shifter assembly - 202,467 miles
Hardened washers for shifter base - 202,467 miles
Fresh Clutch fluid - 207,321 miles
OEM Throw-out bearing - 202,467 miles
Shep Stage 1 transmission - 207,321 miles
FX 2200LB PP - 202,467 miles
FX Multi-friction Race disc - 202,467 miles
resurfaced ACT aluminum flywheel - 202,467 miles
apr flywheel bolts
rebuilt driveshaft w/ carrier bearings 186,973 miles
Redline 75w90 & heavy shockproof - 207,321 miles
Front Axles - 207,321 miles
SS clutch line - 207,321 miles
rebuilt slave and master - 207,321 miles
4 bolt rear end in 4WS housing - 207,321 miles
5 lug conversion - 207,321 miles
Cooling:
Sirocco radiator - 207,321 miles
Mishimoto high flow fan - 207,321 miles
AISIN OEM water pump - 195,785 miles
180 degree thermostat - 207,321 miles
Mishimoto Radiator Hose - 199,532 miles
Greddy radiator cap W/ push release - 205,345 miles
fully flushed and back flushed system - 207,321 miles
Suspension & Handling:
4ws intact
Megan Racing Coilovers - 210,000 miles
whiteline 26mm rear sway bar W bushings- 207,321 miles
Energy bushing kit
Stock rear pads - 191,943 miles
Front and rear rotors - 207,321 miles
Cusco front and rear strut bars - 207,321 miles
All 4 corner Wheel Bearings - 207,321 miles
Moog Steering rack boots - 201,421 miles
Moog sway bar end links - 201,421 miles
Energy Front Sway bar bushings - 201,421 miles
Energy tie rod and lower ball joint caps - 201,421 miles
Non-ABS proportioning valve - 201,421 miles
Rear Adjustable Control Arms - 206,200
Rear Lower Control Arms - 206,200
Rear Moog Sway Bar Endlinks - 206,200
8G Galant Master brake cylinder - 206,200
Rims & Tires:
17" Evo 8 enkei rims 50% tread on tires - 210,000 miles
Gauges & Tuning:
Autometer Z-Series Boost Gauge - 206,200
Autometer Z-Series Oil Pressure Gauge - 206,200
Innovate LC2 Wideband - 208,000 miles
Blitz TT in underdash pocket
ECMLink V3 on S/D
Audio:
Pioneer Headunit w/ AUX
JL Audio rear deck and door speakers
Rockford Fosgates in the dashboard
Interior:
custom floormats
EVO 8 front and rear seats
4 point racing harnesses
Nardi steering wheel
freshly dyed carpet
Custom Cluster surround gauge pod
89 underdash with pocket
Refurbished stock 1g shift boot - 201,421 miles
Rear deck dyed black
Rear Speaker covers replaced with Misfits Cloth
89 Manual Seatbelts
threespeed harness bar - 202,467 miles
89 Glove Box - 206,200
replaced headliner - 207,321 miles
Exterior:
JDM Front Bumper - 202,477 miles
JDM Rear Bumper - 201,421 miles
JDM RS Hood
JDM Rear 1/4 Windows
EDM Amber Corners - 204,389 miles
JDM Door Stickers
Removed wing
3rd brake light installed on rear deck
stubby non-power antenna 203,432 miles
93 clear headlights - repainted - 202,477 miles
Badge Number Sticker
4WS Sticker
Rain Guards
SS fender bolts - 206,271 miles
welded sunroof shut - 205,321 miles
JDM pre-face fogs
Thule Roof Racks
The OEM Window Sticker from 138, not from my vin#
Paints, oils and other misc.
A/C removed
Remounted and repaired wiring.
All emissions are removed.
ABS has been deleted.
Front wheel wells re-rubberized.
I have over 50 pictures of the car, but its a pain to upload them. here are a few photos and if your interested i can e-mail all the photos i have plus any photos you would like.
transparentdsm
Cherry Hill, NJ
Car is sold! im super sad, but its going to a great person and it will be very well take care of. He is a close personal friend and has loved my car since the day he saw it and said if i ever sold it he would want it. so.
We worked out a deal where ill be keeping all of the 138 badge stuff, coilovers and strut tower bars, he is trading me a 1998 TSi FWD Auto and giving me 7k$. im happy because the badge number is actually personal to me and he completely understands this. I also told him i would give him the badge off the 1415/2000 which i had just recently gotten in a trade for my snowmobile when i moved from tahoe.
thomcasey
Indianapolis, IN
He posted what he got above:
"We worked out a deal where ill be keeping all of the 138 badge stuff, coilovers and strut tower bars, he is trading me a 1998 TSi FWD Auto and giving me 7k$"
So, 7k plus a good car and keeping a bunch of stuff. Great price for the seller.
