Finally started 1299 after it being down since 2008. Parked it with barley any fuel in it and pulled the pump out to use on another car. So no fuel, open lines. Got everything back together and can only get it to start with starting fluid. While running it wont take any throttle and will barely idle. While its running I can easily squeeze the fuel feed line. I'm assuming fuel dried up in the line and is causing the issue but i'm not sure so more opinions would be appreciated.
